Grafana v6.0.1 (0c44a04), Debian 10
- What are you trying to achieve?
To be able to display the correct store
- How are you trying to achieve it?
Together with Grafana and Prometheus
- What happened?
Trying to learn how I can use sum and legend
To show the sum for each store
- Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors, Just displays without the store name
- Did you follow any online instructions? If so, what is the URL?
No
