How to use kube_pod_status_phase in a table
Display pod status along side CPU utilization and CPU memory.
With a table visualization
  • What happened?
Can’t get the metric kube_pod_status_phase to display correctly for each pod.
The metric to show the label setting such a Running, Pending, or Backoff
kube_pod_status_phase{cluster=“$cluster”, namespace=“$namespace”, phase=“.*”}
When the metric displays the column name either does show up or shows the wrong value and only 1.0 shows in the column.
Could not find documentation on how to implement it.
