[HOW TO] Table Configuration - w/ Mysql DataSources
Hello All,
I’m trying to use Table module.
I use a MySQL Datasource to get a Count by day, see my SQL request :
SELECT DISTINCT (
DATE( when )
) AS thedate,
COUNT( * ) AS count
FROM login_old
GROUP BY thedate
ORDER BY count DESC
LIMIT 0 , 30
When i check in my PhpMyadmin Interface i get this array :
See my grafana error with table module :slight_smile:
grafana error
skip the DATE(when) part and use DATETIME or just query the date field directly
Hello Torkel,
Thanks a lot for your reply, i found my good query :
I must type my SELECT DISTINCT in a subrequest with the GROUP BY
SELECT COUNT( * ) AS count
FROM login_old
GROUP BY (
SELECT DISTINCT (DATE( when )) AS thedate)
ORDER BY count DESC
LIMIT 0 , 30
But how i can display the Date for each Resuslt in Table Module ?
Convert your DATE to a DATETIME: CONVERT(thedate, DATETIME)
This will create a datetime like this with no time: 2017-03-01 00:00:00
Thanks Daniellee,
where i have to type this CONVERT, in my subrequest ?
:frowning:
It would work both in the subquery or in the select statement in the outer query.
I haven’t tested this but something like this:
SELECT COUNT( * ) AS count,
CONVERT(thedate, DATETIME) AS time_sec
FROM login_old
GROUP BY (
ORDER BY count DESC
LIMIT 0 , 30
Hmm doesn’t work :frowning:
Same in the Subquery :
But i found with this solution :
SELECT COUNT( * ) AS count, when AS date
FROM login_old
GROUP BY
ORDER BY count DESC
LIMIT 0 , 5
I manage with Column style my format Date :slight_smile:
Check my Table :
Thanks a lot for your support daniellee
