i am new to grafana and wanted to understand, how can dashboard be shared with other team members without them installing the grafana
i have used share snapshot, but it doesnot shares the variable drop down list.
Any help is highly appreciated
Grafana is accessed using a web browser. Nobody needs to install Grafana on
their own machine in order to be able to use it - all you need is the URL of
the server where Grafa does run, and authentication credentials.
Antony.
Thanks a lot Antony for the explanation, cleared a lot of basic doubts.
One more query, so does that mean once I put Grafana in server and share URL with others with credentials (with appropriate permissions as View or Edit) , they would be able to see the interactive dashboard with all drop down values of variables created and can set the dashboard as per their requirement?
