I’m trying to setup grafana on heroku but I cant get it to work. What I did is the following:
Premade Docker Container
I tried to release the premade docker container “grafana/grafana”. This is what I did:
heroku stack:set container -a <app>
docker tag grafana/grafana registry.heroku.com/<app>/web
docker push registry.heroku.com/<app>/web
heroku container:release web -a <app>
When executing the release command, heroku gave me the following response:
Releasing images web to <app>... !
▸ No command specified for process type web
So that didn’t work.
Building my own image
I stumbled upon a few stackoverflow threads of users who had the same problem, specifically this one that suggested that I replace ENTRYPOINT
with CMD
in the Dockerfile
, so I cloned the grafana/grafana
repository and did just that. After that I built the container by saying docker build -t grafana/grafana:dev .
. That worked fine and I used the same commands as above (replacing grafana/grafana
with grafana/grafana:dev
) to release the container to heroku and this time it worked, however after 60 seconds the container gets killed because Web process failed to bind to $PORT within 60 seconds of launch
Now I am familiar with this error, what it means is that the application fails to start listening to the port heroku dynamically provides it via the PORT environment variable. The port is not necessarily the same each time so I can’t hardcode it.
How can I get the grafana server to listen to the PORT variable?
