sebelk
December 13, 2022, 12:56pm
1
9.3.1 on RHEL 7
Grants access to publish new public
I didn’t find how to configure roles as in What's new in Grafana v9.2 | Grafana documentation
To find a set permissions to create/edit public dashboard
(Section Use RBAC to allow any user to share dashboards publicly)
Please could you help me to find that in Web GUI on Enterprise edition?
Thanks in advance
Hi @sebelk ,
Thanks for opening this post.
The main link to documentation is at :
where it also states that to enable it need to add the following changes in the Grafana configuration file i.e.:
[feature_toggles]
publicDashboards = true
Let us know if this helps.
sebelk
December 13, 2022, 1:59pm
3
Thanks @usmanahmad
I’ve already read that documentation and edited the configuration file.
In fact, public dashboard is working, but I didn’t find how to enable this:
I only have Admin, Editor and Viewer roles.
Thanks for the quick reply.
I again checked about this feature and it says according to the page :
the “Public Dashboard writer” role if you are using RBAC in Grafana Enterprise or Grafana Cloud Advanced.
Also found here that:
By default, only admins can share dashboards publicly
which implies on the writer feature.
Can you please tell us if you are using Grafana Enterprise or Grafana Cloud Advanced or some other flavour e.g. OSS? and are using the admin account?
