How to set `GROUP BY time(7d)` using the selected time-range in the Dashboard? (instead of fixing it to `7d`)
Grafana 9.2
Ubuntu 20.04
I have the following query, which calculates the total energy consumed in the last 7 days
SELECT SUM("difference")
FROM (
    SELECT DIFFERENCE(MAX("aenergy_total")) AS "difference"
    FROM "pm_shelly"
    WHERE time > now() - 7d
      AND custom_id =~ /^shelly_112|shelly_113|shelly_114$/
    GROUP BY time(7d), "custom_id"
    tz('Europe/Zurich')
tz('Europe/Zurich')
This should output a pie chart like so (using additional, similar querie):
I would now make the time-range for the calculation configurable. I know I can use $timeFilterfor the WHERE clause like so:
FROM (
    FROM "pm_shelly"
    WHERE $timeFilter
    tz('Europe/Zurich')
tz('Europe/Zurich')
But I do not know, how to achieve the same for the GROUP BY time(7d) part, where 7d would need to be set to the same time range.
How do I do this?
EDIT:
Come to think of it: I am not even sure that the original query does what I want. (Which is to calculate the total energy consumed over last 7 days.)
So please critique it and give me feedback on it, if you have any. Thanks!
please click on Query Inspector and post back the query you see there
This is the output as text from the Query Inspector:
A:1 rows
FROM (
    FROM "pm_shelly"
    tz('Europe/Zurich')
tz('Europe/Zurich');SELECT SUM("difference")
FROM (
    FROM "pm_shelly"
      AND custom_id =~ /^shelly_122$/
    tz('Europe/Zurich')
FROM (
    FROM "pm_shelly"
      AND custom_id =~ /^shelly_116|shelly_117|shelly_118|shelly_119|shelly_120$/
    tz('Europe/Zurich')
tz('Europe/Zurich')
B:1 rows
FROM (
    FROM "pm_shelly"
    tz('Europe/Zurich')
FROM (
    FROM "pm_shelly"
    tz('Europe/Zurich')
FROM (
    FROM "pm_shelly"
    tz('Europe/Zurich')
tz('Europe/Zurich')
Here is also a screenshot of both the Query Inspector and appearance in Query editor (below the panel). I add it, because I am confused by the output of the Query Inspector:
do you have a repeat option on your dashboard?
IMHO you don’t need GROUP BY time/timeseries at all, because used visualization doesn’t have time dimension.
No. The repeat option is not set on the dashboard or panel. But thanks for the pointer… I learned something! :slight_smile:
Thanks for you suggestion. However, if remove the time(7d) in the GROUP BY statement, then I get this error:
Query error
InfluxDB Error: difference aggregate requires a GROUP BY interval
For completeness, this is the query without time(7d) that produces the error:
FROM (
    FROM "pm_shelly"
    GROUP BY "custom_id"
    tz('Europe/Zurich')
tz('Europe/Zurich')
Dig deeper. You should understand your data model. I don’t, but I’m scratching my head - why you need difference? My naive idea:
should be
SELECT SPREAD("aenergy_total") AS "difference"
and I think this is even more precise if aenergy_total is a counter.
