I’ve setup a singular alertmanager integration in Grafana Oncall to receive alerts for various teams. I am noticing that alert groups from alerts coming into this integration only inherit the team from the integration which is corroborated by the docs here. Is there any way to change this behaviour? I would prefer to not have to manage multiple separate team-specific integrations if they are all coming from the same instance of alertmanager.
Yes. You need to create a separate contact point for each team, and then add the integration set for that team to each contact point. Alerts are routed to a contact point by either explicitly setting a specific contact point or routing the alert via the notification policies; you choose this in “4. Configure Labels and notifications” in the alert.
