I want to replace a SQL return value with a text based on the value. The value can be ‘0’ or ‘1’ but when the SQL matches to 1, I would like to replace that with a Text value and display that in table.
Like if returned value is 1, then “On_home” else “Off_home”
My query is as below –
select id1,system, duration, state_a, state_z, on_home
FROM tables1
WHERE
Case
on_home = ‘1’ THEN “On_Home”
Else “off_home”
End
ORDER BY system;
I am trying to print them in a table but unfortunately the table is empty.
The SQL query works fine if i use as below
FROM tables1
WHERE on_home = ‘1’
ORDER BY system;
but the issue is that on_home column prints value 1 which I want to be replaced with text as above
Thanks,
