Hello All,
How to remove the default namespaces in openshift4 using promtail configmap.
Here is the configmap configuration.
positions:
filename: /tmp/positions.yaml
target_config:
sync_period: 10s
scrape_configs:
- job_name: custom-config
pipeline_stages:
- cri: {}
- match:
selector: '{app="^;*([^;]+)(;.*)?$"}'
stages:
- regex:
expression: "^(?s)(?P<time>\\S+?) (?P<stream>stdout|stderr) (?P<flags>\\S+?) (?P<content>.*)$"
- labels:
stream:
application_log: application_log
- timestamp:
source: time
format: RFC3339Nano
- output:
source: content
- multiline:
firstline: ^\x{200B}\[
max_lines: 128
max_wait_time: 3s
- replace:
expression: (\n)
replace: ""
# - match:
# selector: '{app="^;*([^;]+)(;.*)?$"}'
# stages:
# - regex:
# source: content
# expression: '(?P<timestamp>\\d{4}-\\d{2}-\\d{2} \\d{2}:\\d{2}:\\d{2}.\\d{3}) \\| (?P<level>DEBUG|INFO|WARN|ERROR) \\| (?P<thread>.+?) - (?P<thread_id>\\d+) \\| (?P<service_name>.+?) \\| (?P<context>.+?) \\| \\| \\| (?P<message>.+)'
# - labels:
# timestamp:
# level:
# thread:
# thread_id:
# service_name:
# context:
# - timestamp:
# source: timestamp
# format: '2006-01-02 15:04:05.000'
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
action: replace
target_label: __tmp_controller_name
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_name
- __tmp_controller_name
- __meta_kubernetes_pod_name
regex: ^;*([^;]+)(;.*)?$
action: replace
target_label: app
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_instance
- __meta_kubernetes_pod_label_release
action: replace
target_label: instance
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_component
- __meta_kubernetes_pod_label_component
action: replace
target_label: component
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
replacement: $1
separator: /
source_labels:
- namespace
- app
target_label: job
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- action: replace
regex: true/(.*)
separator: /
source_labels:
- __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
- __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
