How to remove Horizontal scroll bar in bar gauges
I have upgraded from 10.4.2 to 11.0.3, later i see the horizontal scroll bar in bar guage, I tried to remove it, but did not find expected outcome. Please help me to remove the scroll bar. I followed this link-12510 as well But not working as expected.
if you make the panel bigger, do they go away?
No, It’s not going away and we don’t need panel enlargement. The panel size should remains same and that horizontal scroll bar should go away.
You might want to check if there are any layout settings that could be adjusted in the configuration Manga go. Sometimes, tweaking the size or margins can help eliminate the scroll bar.
There is no layout settings to adjust the scroll the bar
