How to remove double quotes using rename by regex?
I have the legends displayed like below in timeseries panel,
value{name="server1",sensor="Temp",min="-1.00",max="1.00"}
I want to display it like below,
name:server1, min:-1.00, max:1.00, sensor:Temp
How can I do?
You can do it with multiple regexes.
For example, if the value in the legend looks like this:
regex1
Than the following 3 regexes convert it to this:
The first regex removes the value string and the brackets
The second removes the first set of quotation marks
The third removes the second set of quotation marks
