How to print annotations?
Is there a way to have annotations printed when printing grafana output (to pdf on printer)?
Currently annotations are shown only when moving mouse on it.
That’s not supported and seems like a tricky thing to support and/or hard to find a solution that will suit users having a lot of annotations. Would it be possible for you to use a table to display the annotations instead, see example.
If you really want this feature I would suggest you to create a feature request issue. If lots of people upvotes the issue with a thumbs up emoji we’ll consider implementing/merging it.
Marcus
