7.03 -
I am trying to use the Opentsdb plugin with grafana.
I would like to calculate the rate per second. I have data that returns a sliding total of every 5 minutes. -
To find my sliding total, I run a transform and divide by 300. This works fine when am not doing any filtering (See the query slide)
- What happened?
However, when I try to filter my data, the transform hardcodes the alias.
(See the transform side). Also, there is no way to preserve the variable name in the returned column.
The transform should treat the variable alias as a template, not a hard coded value -
