How to poll X-Ray data from AWS to Grafana?
We are using Grafana to monitor our AWS resources. Our current structure:
  • YACE → Prometheus (CloudWatch metrics)
  • Fluentd → Loki (CloudWatch Logs)
  • Thanos (Long-term storage)
  • Grafana (Visualization)
    We also have AWS X-Ray active tracing enabled on all of our Lambda functions, and Grafana can query X-Ray directly for live trace data. However, X-Ray only retains traces for 30 days, and we need long-term storage to match what we already have for metrics and logs.
    Ideally, we’d like a tool that can poll or scrape X-Ray trace data — similar to how YACE polls CloudWatch metrics — so we can store it long-term. Modifying our Lambda functions to send traces to an external collector isn’t feasible since they all use AWS-native active tracing with no custom instrumentation. We haven’t been able to find any open-source project that pulls trace data from the X-Ray API. Does anyone know of a tool or approach that fits this use case?
TL;DR: How to scrabe/poll the AWS X-Ray Data?
I guess you are using ADOT, so there is OTEL collector under the hood and you can configure it to export traces also to other destinations, e.g. to your Tempo instance.
We considered the ADOT dual-export approach, but it requires structural changes across all our Lambda functions - adding ADOT layers. Since we have many Lambdas already running with native X-Ray tracing (tracing_mode = Active), we’d rather keep the existing setup untouched and instead poll the X-Ray API from the observability side to pull traces into Tempo for long-term storage. But I could not find any tool (or project) to poll the X-Ray.
Note: I actually need the same approach in the metrics (YACE and Prometheus) for the X-RAY data.
Quick search:
IMHO pulling is fine for small load, but it may have problem with higher load.
