How to migrate the alerts from Grafana 7 th version to 10
, How to migrate the alerts from Grafana 7 th
Welcome @sasimaha818
There have been so many changes since then that I suggest you just wait a few weeks for V11, and then rebuild all of your alerts from scratch. Keep v7 running on a separate machine if you can so you can refer to it while you rebuild the alerts in V11.
