How to migrate from single s3 bucket to multiple s3 buckets
Hi, I’m using s3 as loki storage with single bucket, and I’m having s3 rate limit issue recently.
so I’d like to use multiple s3 bucket and I don’t know how to migrate single s3 bucket to multiple s3 buckets.
Is there any guide to migrate single s3 bucket to multiple s3 buckets?
I found this topic, and the s3_multi config doesn’t work.
I replied to your response in that thread. You don’t have to define S3 bucket under common (in fact that’s the old way of doing it if i remember correctly). Try to simply define it under storage_config.
What I would recommend you to do:
  1. Stand up a dev cluster.
  2. Find a config that works with multiple S3 buckets.
  3. Terminate the dev cluster, and re-deploy with a single S3 bucket (mirroring your production cluster configuration).
  4. Attempt to migrate to multiple S3 buckets by adding a new S3 bucket configuration and a new index segment. Test and make sure cluster is functional after migration, and logs from before and after migration are visible.
I unfortunately have never attempted this before, these are just my thoughts.
