How to install K6 binary on AWS ec2 , ec2 is based in linux
Hi Team , how can i install k6 binaries on AWS EC2 which is based on linux.
HI @sandeeprawat, I propose you just use the provided compiled binaries on the release page.
Otherwise you will need to see what distribution you use and look for a package for that distribution, but we only support ubuntu and CentOS ourselves, so if you use something else you will need to trust whoever made the package did it okay :slight_smile:
