I would like to know proper way to install Grafana in litespeed server.
I used following method but it is not working in litespeed server. But it work without litespeed server.
sudo apt-get install -y apt-transport-https software-properties-common
wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
sudo apt-get update
sudo apt-get -y install grafana
sudo systemctl enable grafana-server
sudo systemctl start grafana-server
When install Grafana in Litespeed Server, following things happening.
- High CPU used (90% - 100%)
- Port not loading when Firewalls allowed 3000 port
- when check port using
sudo ss -tulnp | grep 3000
give following details. Not grafana.
tcp LISTEN 0 4096 127.0.0.1:3000 0.0.0.0:* users:(("nghttpx",pid=572,fd=5),("nghttpx",pid=540,fd=5))
- when changed port, it is not working.
cat /etc/grafana/grafana.ini
then sethttp_port = 5000
sudo systemctl restart grafana-server
sudo service grafana-server restart
- when check new port,
sudo ss -tuln | grep 5000
, not showing anything
How to solve this issue?
