Hi ,
Is it possible to get user information in a custom panel plugin ? Retrieving a userId will be sufficient for me .
Thank you in advance
Hi ,
If I understand, It’s possibile using Grafana API
This should be a possible piece of your code:
this.backendSrv.get('/api/users')
.then((result) => {
user_infos = _.filter(result, {"name": "my_user"});
where “my_user” could be the username you are looking for information.
(code not tested and incomplete)
I’m assuming @rernas is looking for the ID/info of the currently logged in user (who’s viewing the plugin), rather than an arbitrary user with a known username. I’d be interested in knowing the answer to that question also.
So maybe this is useful:
