Grafana Version 6 hosted on an internal devx server -
FieldA | FieldB | Status | Time
- A1 | B2 | Pass | 10.00
- A1 | B2 | Fail. | 10.03
- A2 | B3 | Pass. | 10.04
What i want is: Count of FieldA that have passed and failed.
Passed: 1 (Entry 3 @10.04)
Failed : 1 ( Entry 2 @10.03 because that is the latest status for FieldA A1)
- How are you trying to achieve it?
I have used Top hits in grafana as below:
And then i am using Group By → Terms - > Field A
This way, i am able to generate a table as below:
The resultant table has the contents intended. But i need the count of Pass and Fail from this table.
What happened?
When i change the visualization to anything other than table(like Single stats, stats, piechart) and try to get the count , it fails.
I have also tried Derivative, and bucket script as below:
To get the count of Passed and Failed from the output table of Top hits. -
No errors, just the count is not displayed.
