Hi.
I’m using the auto-provisioning feature of Grafana: https://grafana.com/docs/administration/provisioning/ to manage my dashboards remotely.
I’ve set the updateIntervalSeconds parameter to 600, so it should check every 10 minutes for an update to the dashboard.
However, nothing changes on my wallboard display unless I manually refresh the browser after the new dashboard has been found and implemented, so the auto-update feature isn’t really automatically updating.
I’m using Chromium browser under Debian 9 ‘Stretch’ Linux with Grafana 6.2.4 on a separate Debian 9 ‘Stretch’ machine, and the dashboard update interval is set to 30 seconds.
Have I missed some configuration (I’ve basically used the template at https://grafana.com/docs/administration/provisioning/#dashboards with very little modification) which is needed so that the browser display actually changes when I modify the dashboard definition?
Thanks,
Antony.
