How to get absolute value with Query?
Hi, I’m studying Grafana with InfluxDB.
I want to change the measurement value to the absolute value.
How can I do this?
Someone says to use “SELECT * FROM * ~~~” but it doesn’t work.
My code is as follows.
Thanks for your help.
from(bucket: v.defaultBucket)
|> filter(fn: (r) => r[“_measurement”] =~ /${DEVICE:regex}/)
|> filter(fn: (r) => r[“_field”] == “current1” or r[“_field”] == “current2”)
|> aggregateWindow(every: v.windowPeriod, fn: mean)
|> yield(name: “mean”)
Try putting this before your yield statement:
|> map(fn: (r) => ({r with _value: math.abs(x: r._value)}))
You may also want to place the above statement before the aggregateWindow statement and see how your results change.
Thank you so much. It works very well.
