How to FortiGate monitoring with Influxdb and Telegraf
I’m thinking of developing monitoring for Fortigate using influxdb and telegraf. So far, I have designed a dashboard consisting of these data. Fortigate’s CPU, ram, and session information are coming.
But I want to capture and display network traffic like which IP addresses use how much network.
I am sharing my Telegraf.conf file and dashboard below.
InfluxDB v2.5.1 (git: 5b6fdbf05d)
Grafana *v8.2.3 (fb85ed6912)
Telegraf v1.24.3 (git: HEAD@ff7323e1)
[[inputs.snmp]]
   agents = [ "IP_ADDRESS:161" ]
   timeout = "5s"
   retries = 3
   version = 2
   community = "monitoring"
#   ## SNMPv3 auth parameters
   sec_name = "sec_name"
   auth_protocol = "MD5"      # Values: "MD5", "SHA", ""
   auth_password = "pass"
   sec_level = "authPriv"   # Values: "noAuthNoPriv", "authNoPriv", "authPriv"
   #context_name = ""
   priv_protocol = "AES"         # Values: "DES", "AES", ""
   priv_password = "pass"
  name = "FortiGate"
  [[inputs.snmp.field]]
    name = "hostname"
    oid = "SNMPv2-MIB::sysName.0"
    name = "sysLocation"
    oid = "SNMPv2-MIB::sysLocation.0"
    name = "uptime"
    oid = "DISMAN-EXPRESSION-MIB::sysUpTimeInstance.0"
    name = "fnSysSerial"
    oid = "FORTINET-CORE-MIB::fnSysSerial.0"
    name = "fgSysVersion"
    oid = "FORTINET-FORTIGATE-MIB::fgSysVersion.0"
    name = "fgSysUpTime"
    oid = "FORTINET-FORTIGATE-MIB::fgSysUpTime.0"
    name = "fgSysMemUsage"
    oid = "FORTINET-FORTIGATE-MIB::fgSysMemUsage.0"
    name = "fgSysCpuUsage"
    oid = "FORTINET-FORTIGATE-MIB::fgSysCpuUsage.0"
    name = "fgSysMemCapacity"
    oid = "FORTINET-FORTIGATE-MIB::fgSysMemCapacity.0"
    name = "fgSysDiskUsage"
    oid = "FORTINET-FORTIGATE-MIB::fgSysDiskUsage.0"
    name = "fgSysDiskCapacity"
    oid = "FORTINET-FORTIGATE-MIB::fgSysDiskCapacity.0"
    name = "fgSysSesCount"
    oid = "FORTINET-FORTIGATE-MIB::fgSysSesCount.0"
    name = "fgSysLowMemUsage"
    oid = "FORTINET-FORTIGATE-MIB::fgSysLowMemUsage.0"
    name = "fgSysLowMemCapacity"
    oid = "FORTINET-FORTIGATE-MIB::fgSysLowMemCapacity.0"
# IF-MIB::ifXTable contains newer High Capacity (HC) counters that do not overflow as fast for a few of the ifTable counters
  [[inputs.snmp.table]]
    name = "FortiGate-interface"
# Interface tag - used to identify interface in metrics database
    [[inputs.snmp.table.field]]
      name = "ifName"
      oid = "IF-MIB::ifName"
      is_tag = true
      name = "ifHCOutOctets"
      oid = "IF-MIB::ifHCOutOctets"
      name = "ifHCInOctets"
      oid = "IF-MIB::ifHCInOctets"
#FORTINET-FORTIGATE-MIB::fgVdTable
    name = "FORTINET-FORTIGATE-MIB::fgVdTable"
    inherit_tags = [ "hostname" ]
    oid = "FORTINET-FORTIGATE-MIB::fgVdTable"
#FORTINET-FORTIGATE-MIB::fgVdEntName
      name = "fgVdEntName"
      oid = "FORTINET-FORTIGATE-MIB::fgVdEntName"
      is_tag = true
#VPN
    ## measurement name
    name = "fgVpnTun"
      name = "fgVpnTunEntPhase1Name"
      oid = "FORTINET-FORTIGATE-MIB::fgVpnTunEntPhase1Name"
      is_tag = true
      name = "fgVpnTunEntPhase2Name"
      oid = "FORTINET-FORTIGATE-MIB::fgVpnTunEntPhase2Name"
      is_tag = true
      name = "fgVpnTunEntInOctets"
      oid = "FORTINET-FORTIGATE-MIB::fgVpnTunEntInOctets"
      name = "fgVpnTunEntOutOctets"
      oid = "FORTINET-FORTIGATE-MIB::fgVpnTunEntOutOctets"
      name = "fgVpnTunEntStatus"
      oid = "FORTINET-FORTIGATE-MIB::fgVpnTunEntStatus"
#HA
    ## measurement name
    name = "fgHaStats"
      name = "fgHaStatsHostname"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsHostname"
      is_tag = true
      name = "fgHaStatsSyncStatus"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsSyncStatus"
      name = "fgHaStatsCpuUsage"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsCpuUsage"
      name = "fgHaStatsSerial"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsSerial"
      name = "fgHaStatsMemUsage"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsMemUsage"
      name = "fgHaStatsNetUsage"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsNetUsage"
      name = "fgHaStatsSesCount"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsSesCount"
      name = "fgHaStatsPktCount"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsPktCount"
      name = "fgHaStatsByteCount"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsByteCount"
      name = "fgHaStatsIdsCount"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsIdsCount"
      name = "fgHaStatsAvCount"
      oid = "FORTINET-FORTIGATE-MIB::fgHaStatsAvCount"
      name = "Uptime"
      oid = "iso.3.6.1.2.1.1.3.0"
      name = "Memory"
      oid = "iso.3.6.1.4.1.12356.101.4.5.3.1.7.1"
      name = "CPU"
      oid = ".1.3.6.1.4.1.12356.101.4.1.3.0"
       name = "Sessions"
       oid = "1.3.6.1.4.1.12356.101.4.1.8.0"
       name = "OF"
       oid = ".1.3.6.1.4.1.12356.101.8.2.1.1.1"
       name = "Red"
       oid = "1.3.6.1.4.1.12356.101.13.2.1.1.5.1"
       name = "disk usage"
       oid = "1.3.6.1.4.1.12356.101.4.1.6.0"
       name = "LAN - Entry"
       oid = "1.3.6.1.2.1.31.1.1.1.6.8"
       name = "VAN - Entry"
       oid = "1.3.6.1.2.1.31.1.1.1.6.1"
Grafana Dashboard:
If there is a dashboard and/or telegraf.conf file ready for Fortigate, could you please share it?
Thanks.
