Hi all,
Can anyone let me know how to find and remove specific word in Elastic search
for example :
millsec 018ms
I need to remove the text “ms” from 018ms.
Hi all,
for example :
millsec 018ms
Not sure Grafana can help you with that if you’re referring to removing it in a query result. For this I would suggest you to change how you write documents to your elasticsearch indices. Basically if you have a string value in es and want it to be a numeric one I definitely suggest you to actually write the numeric value with a numeric data type in your es document. If you’re using a template variable you may be able to do it using a regular expression.
Marcus
