How to exporting CSV file using the Grafana-Image-Renderer?
Hi All,
I’m using grafana-image-renderer to export chart images to generate some report document. And I’ve check the release note v3.0.0, grafana-image-renderer has been added rendering csv feature.
But, I can’t find the entry point (or link) to export CSV file using the grafana-image-renderer. And also I can’t find any document for how to use grafana-image-renderer’s csv API (/render/csv).
Is there useful document to use grafana-image-renderer? Currently I use the community version 7.5.10 and 8.1.5.
ps. I can’t use “Panel->Inspect->Data + CSV options” on browser because our team want to export CSV files at the end of some event duration automatically.
I believe that this is now a feature of Enterprise Reporting.
https://grafana.com/docs/grafana/latest/enterprise/reporting/
