By default the value that is displayed is the average of the values it retrieves from the backend for the granularity being viewed. For example, if you are looking at a chart that has a value for every five-minutes, the value you are seeing is the average of all the values for that five-minute period.
Is there any way to change this behavior to display a max or an aggregate instead of the average?
