How to disable the image (the chart capture/screenshot) in the notification messages? As you can see, the “include image” checkbox is unchecked, but still we see the images:
Grafana Open Source 7.5.2
- What are you trying to achieve?
Have a single message (text) without the chart capture
- How are you trying to achieve it?
Disabling the corresponding option in the notification settings
- What happened?
The capture is still there
Having the capture removed
No specific errors
- Did you follow any online instructions? If so, what is the URL?
I did not found more help
