Hi All,
Is there any way to disable htpasswd authentication for Grafana?
Currently I have to create one user using below command
/usr/bin/htpasswd -cs /var/broadhop/.htpasswd
So when I visit ‘http://10.77.207.103:80/grafana/’, I have to use credentials of created just above and then login using admin credentials.
May I know how can I bypass first level(.htpasswd) of authentication for grafana?
Not sure I understand this question. htpasswd is the Apache (or maybe Nginx) authentication, what does that have to do with Grafana? Is this a question about how to configure Apache/Nginx?
Per default Grafana does not use htpasswd authentication, see blog post below that describes how to configure it to use an auth proxy:
https://grafana.com/blog/2015/12/07/grafana-authproxy-have-it-your-way/
Thank you Daniel! I had to change my ‘/etc/httpd/conf.d/grafana-proxy.conf’ and restart httpd. After above action, it started bypassing ‘.htpasswd’ file for authentication.
