How to disable grafana.navigation.docked localstorage variable by default
Grafana Version: v10.4.0
I’ve noticed that this new grafana version set’s the localstorage variable grafana.navigation.docked = true by default. This causes the left-hand-side navigation menu to be docked on dashboard load. Is there a way to set this to false by default?
What I’m expecting: setting this to false by default will cause that menu to not be docked on dashboard load.
What I’ve tried: looked for url parameters to set this variable, could not find one. Also, maybe this can be set by modifying the .ini file?
Thanks in advance for any assistance!
I’ve also been looking for a way to set grafana.navigation.docked to false by default. Hoping we can get a solution or guidance from the Grafana team here.
Would also appreciate an option to disable that by default. it’s annoying.
To solve this I changed
this.megaMenuDocked=!!(window.innerWidth>=j.$.theme2.breakpoints.values.xl&&ri.A.getBool(Eu,window.innerWidth>=j.$.theme2.breakpoints.values.xxl))
to
this.megaMenuDocked=false
in one of .js files in public/build
Also looking for safer solution…
You are a life-saver. Detailed instructions which work on my linux server:
  1. Go to the /usr/share/grafana/public/build
  2. Search this.megaMenuDocked with ripgrep: rg this.megaMenuDocked *.js -c. In my case it is in the file 4570.87a4acc6d9144f9ee50a.js.
  3. Make backup copy cp 4570.87a4acc6d9144f9ee50a.js /home/username
  4. Open original js file with text editor, e. g. micro: micro 4570.87a4acc6d9144f9ee50a.js
  5. Find ‘this.megaMenuDocked=’, replace right-hand side (long expression !!(window.innerWidth>=j.$.theme2.breakpoints.values.xl&&ri.A.getBool(Eu,window.innerWidth>=j.$.theme2.breakpoints.values.xxl))) with false
  6. Save the file.
Now the sidebar will be undocked by default as it should be. It is a very unsafe solution, use it at your own risk.
As a side note, the visible by default this huge sidebar is absolutely contrary to what is called “put content first”. I am really interested in the reasons for such a design decision.
Also looking for a “safe” way to make this menu UNDOCKED by default.
About to upgrade our org from 10->11, and during testing this is the first thing everyone is commenting on.
I get it’s not a huge deal to expect users to undock this, but it’s making the upgrade just a little GROSS when it could be seemless
This should be a config setting, and IMHO should be defaulted to UNDOCKED
Thanks for the workaround !
I observed that there may be some variations around the right-hand side expression to replace, depending on the grafana 11.x version. Here is a one liner (using sed with a regex) linux command to perform the replacement, this is still not a safer solution but can be useful for industrialisation (e.g in a Dockerfile):
find public/build -type f -name "*.js" | xargs sed -i 's/this.megaMenuDocked=\(!!\(.*\)xxl)),\)/this.megaMenuDocked=false,/g'
Tested for grafana 11.1.4. Hope this helps.
