Instead of “Viewers” I would like the default grafana group to be “Editors”. I know about “viewers_can_edit” but would prefer to change the default group. I am deploying via prometheus-operator (to k8s). Thank you for reading.
Hi @guycole,
Have you explored the auto-assign-org-role
in the grafana.ini?
Are you using anonymous authentication? If not, what are you using?
No, but I will try an experiment right after responding. I saw the option, but I know who my users are.
We use Active Directory with auth.proxy. It works. For production reasons, I cannot get groups from AD at the moment, so this is only temporary.
Thank you for the suggestion.
thanks for the information.
thanks my issue has been fixed.
