How to decommision grafana dashboard
Hi Team,
Is there any way to decommision Grafana dashboards.
You mean like delete a dashboard? Click on the gear wheel and scroll to the bottom - there’s a “Delete Dashboard” button there
delete option I have seen, it will delete the dashboard permanently, I am searching for decommisioning
Ok, got it. In that case maybe you could describe what specifically you mean by “decommissioning”? What is your desired outcome?
We can say that the dashboard will be present in Grafana but in inactive state.
Ok. How would you like an inactive dashboard to behave? Visible only to admins but not to regular users? You can set permissions in a way that achieves that for example
