How to create y-axis separation lines?
I have a graph where a part of the data is some days in the future and the other part is in the past.
Is it possible to add y-axis separation lines (between past and future or on day change)?
Can you draw what mean?
The green line indicates the border between past and future. It makes it a lot easier to read the graph, cause i dont have to look at the x axis and think about the dates.
A separation line would also be handy with other scenarios. eg: mark the time where a valve switched, backup started, etc
