I have configured grafana successfully with prometheus database.
I am using grafana v13.0.1 on windows 2019 to monitor windows servers.I want to be guided on how to create functional filters to allow me filter only servers with high resource utilization
GRAFANA FORUM’S 3 BEST PRACTICES:
- Please post inside a subcategory
- For questions and advice, please try to use the template below
- If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
What happened?
Welcome @ibspace to the community
Verify Your Metric Names
Run this in Prometheus first (http://localhost:9090/query):
promql
windows_cpu_time_total
If no data returned, try wmi_cpu_time_total → use whichever works in all queries below.
Create Two Dashboard Variables
Dashboard Settings → Variables → Add variable
Variable 1 → Server filter:
| Field |
Value |
| Type |
Query |
| Name |
instance |
| Label |
Server |
| Data source |
Prometheus |
| Query type |
Label values |
| Label |
instance |
| Metric |
windows_cpu_time_total |
| Multi-value |
ON |
| Include All |
ON |
Variable 2 → Threshold:
| Field |
Value |
| Type |
Textbox |
| Name |
cpu_threshold |
| Label |
High Utilization Above (%) |
| Default |
80 |
Create a Stat Panel with This Query
Add new panel → choose Stat visualization → paste this query:
CPU:
promql
(100 - (avg by(instance)(rate(windows_cpu_time_total{mode="idle", instance=~"$instance"}[5m])) * 100)) > $cpu_threshold
Memory :
promql
(100 - ((windows_os_physical_memory_free_bytes{instance=~"$instance"} / windows_cs_physical_memory_bytes{instance=~"$instance"}) * 100)) > $cpu_threshold
Disk Usage :
promql
(100 - ((windows_logical_disk_free_bytes{instance=~"$instance", volume!~"HarddiskVolume.*"} / windows_logical_disk_size_bytes{instance=~"$instance"}) * 100)) > $cpu_threshold
Set Color Thresholds
Right panel → Thresholds:
Green Base → 0
Yellow → 60
Red → 80
Color scheme → From thresholds (by value)
Test the Filter
Set cpu_threshold = 80 → only servers above 80% appear
Set cpu_threshold = 99 → only critically loaded servers appear
Panel empty = all servers healthy
The
> $cpu_threshold in the query is the key → Prometheus only returns servers exceeding the threshold, others disappear automatically. No extra transformations needed.
Hello Shanker,
I am glad to join the grafana community.
I will follow the steps.
Thank you so much for your support.
Best Regards.
Thanks @ibspace I just wanted to know did the solution work out for you? I can help further if you’re still running into any issues.
Hello Shanker,
Thank you for your support.
I realized that i can always sort the metrics in ascending or descending order which will give me result for ‘Critical’,‘Warning’ and ‘Normal’.
However i will implement your guide in my next project.
Kindly assist me with the request below:
I used the json file attached to create a dashboard for monitoring Windows servers, but i realized that the dashboard captures only C and E drives even though some of the servers have more drives: C,E,F,G.
Please guide me on how to make grafana capture all the available drives, i have confirmed that windows exporter reports the metrics correctly on prometheus using this command windows_logical_disk_size_bytes{instance=“IB_Space:9182”}
Best Regards.
(attachments)
18658_rev1.json (53.4 KB)
I checked your JSON dashboard and found the issue. The Server Capacity table has hardcoded queries for only C: and D: drives, so drives like E:, F:, and G: are never displayed.
Replace both hardcoded disk queries with this single dynamic query:
100 - ((windows_logical_disk_free_bytes{instance=~"$instance", volume!~"HarddiskVolume.*"} / windows_logical_disk_size_bytes{instance=~"$instance", volume!~"HarddiskVolume.*"}) * 100)
Set the Legend field to:
{{volume}}
If the table still doesn’t display all drives correctly, update the Organize fields and Group By transformations by removing the hardcoded C: and D: column references so the dynamic disk series can be displayed correctly.
