How to create external link with regex variable?
    v10.1.0 / Redhat
    I would like to create a link to an URL using a variable shortened by regex.
    a) make a variable to get an information.
    b) Use regexp to shortened the value.
    c) Use the short variable to make an URL in link.
  • What happened?
    Grafana use the raw variable (long) to build the URL.
    I would like to have the URL with the small variable.
    Sure !
    My raw variable called “module” :
Let’s clean it up for getting a shorter value :
How i’m building the link :
Let’s clic on it :
2023-11-27_141218
This is not the good value :frowning: :
    No.
    I haven’t find information about that.
Does anyone have an idea ?
