How to create a solid menu structure for multiple dashboards?
7.5.7
Create a solid menu structure for 3 dashboards
By using the default dashboard switcher:
  • What happened?
I’m down to use the standard dashboard switcher (see image above) but theres no dropdown ( should be on red rectangle in above image), if an user wants to switch it replaced the entire screen with the search option for dashboards, this is not desirable:
There to be a key-down dropdown icon with all the dashboards located in that specific Folder u are currently in.
Hope someone can help, thanks in advance!
