How to create a dashboard from ElasticSearch logs
I have connected grafana to an elasticsearch data source. The goal is to create metric dashboards out of elastic search logs. I have two lucene queries in grafana. The first query retrieves all logs in the specified log path
log.file.path:\/data\/gitlab\/logs\/gitlab-rails\/release_job_logs.json AND fields.environment:production
The second query retrieves logs in the specified path that has a ‘success’ value in the json.job_status field
log.file.path:\/data\/gitlab\/logs\/gitlab-rails\/release_job_logs.json AND fields.environment:production AND json.job_status:success
I will like to create a dashboard that creates a percentage of the logs with a ‘success’ value in the json.job_status field.
So essentially if the first query gives me a count of 100 and the second query gives a count of 90 then the dashboard should display 90%. Which will mean 90% of all logs have a json.job_status:success
The image below shows what I have now from the two queries above. How do I get a percentage dashboard
Hi there,
Just go to transformation, then select Add field from calculation
Then select Binary Operator
Select the first value, then select the operation to /, last, select the second value.
Put the alias as Success Percentage
After this, you need to Override each of the alias, especially the unit
Put the unit as none for the first and second value, but the third value, select Percentage 0-1
And you will get the new Gauge as percentage.
Regards,
Fadjar Tandabawana
Thanks for your answer.
Transform completely gives me a wrong percentage and also converts the first gauges into the percentage value. So say the percentage value is 10% ( which is wrong), the first gauges will be 10 and last gauge produced by transform will be 10%. I cant figure out why
You need to go to the Override in the right pane and below after you scroll down.
Check the override per field and then add the override property, find the standard option - unit.
You can change the unit per override
Regards,
Fadjar Tandabawana
As you can see from the image, I have changed the overrides. I cant figure out what is wrong
Please let me know the override config for the Success Percentage, also try to save it first then refresh.
Regards,
Fadjar Tandabawana
It looks like this,
        "overrides": [
            "matcher": {
              "id": "byName",
              "options": "log.offset 1"
            "properties": [
                "id": "unit",
                "value": "none"
            "matcher": {
              "id": "byName",
              "options": "log.offset 2"
            "properties": [
                "id": "unit",
                "value": "none"
            "matcher": {
              "id": "byName",
              "options": "Success Percentage"
            "properties": [
                "id": "unit",
                "value": "percentunit"
Try to select the calculation to the Last*
Regards,
Fadjar Tandabawana
That gives me 100% . I dont mind changing the gauge to another visualization…say stat or piechart for example
