I am working with Geneva as a data source, which does not allow our metrics to be output as a table format. I am wondering if I would be able to use either the expressions or transformations features to convert the data to table? I could then finish parsing through the results with regex.
Recently, I use the iotdb time series data source,
Meybe you can introduce objects one by one as query queries.
Then,you can use regex in grafana
How would I be able to separate each object, would I have to change the data source metric?
Geneva only supports data output as large preaggregates. I don’t think your solution would work. I’m asking if Grafana has a way to convert the aggregated series to a table view.
