How to configure Grafana (docker) behind haproxy
I’m trying to setup the Grafana 6.2.2 docker image behind haproxy but, despite following the documentation, I am having a hard time figuring out to pass the configuration to Grafana.
I going with the “subpath” config. Grafana will be available via <host>/whatever url.
From the doc:
[server]
domain = foo.bar
root_url = %(protocol)s://%(domain)s/grafana/
Where do I set this Grafana configuration? How do I pass it to the Grafana image and/or container?
As for the domain section, is it mandatory? What if the host is an IP address? What if this address changes?
That’s a lot of question (and a lot of confusion on my side) :slight_smile:
Thank you in advance for your help.
Mila
Up :slight_smile:
Any help on this one ? :frowning:
Hello ,
did you every got the answer ? Please share I am trying to do the same !
