I’m running a Docker Swarm cluster and want to use Grafana Alloy to send container logs to Loki.
if we use docker discovery I think we will have an issue (The container name changes on every restart or reschedule)
- Do I need to run Alloy on every Swarm node (as a global service) to collect logs cluster-wide?
- Is there a way to configure Alloy so that it can pull logs for all Swarm services directly from the manager node, like
docker service logs does?
Thanks!
I don’t use Docker Swam myself, but I would recommend you to run alloy on all nodes.
Can anyone using alloy to monitor a docker swarm cluster help me by sharing the config?
I’m using:
discovery.dockerswarm "swarm" {
host = "unix:///var/run/docker.sock"
role = "tasks"
filter {
name = "desired-state"
values = ["running"]
and targets are discovered correctly.
After this, I tried with component loki.source.docker:
loki.source.docker "swarm_reader" {
targets = discovery.dockerswarm.swarm.targets
forward_to = [loki.write.endpoint.receiver]
but no logs send to loki.
So I tried with loki.source.file with custom __path__ from swarm metadata:
discovery.relabel "swarm_logs" {
rule {
source_labels = ["__meta_dockerswarm_task_container_id"]
target_label = "__path__"
replacement = "/var/log/containers/${1}-json.log"
rule {
source_labels = ["__meta_dockerswarm_service_name"]
target_label = "service"
loki.source.file "swarm_tasks" {
targets = discovery.relabel.swarm_logs.output
Anyone could help me?
Please start a new thread. Also, more information would be great, such as if there were error logs from Alloy and if any other pipeline is working.
