What is the procedure please to adopt after checking out a different version to clean the build environment before a new build?
I am guessing that for the backend I should do
go run build.go clean
go run build.go setup
go run build.go build
but for the frontend assets is it sufficient to do
yarn install --pure-lockfile
yarn start
or is there something else to do first?
