How to change the default Font
Dear all,
the “Inter” seems the default Font, I tried to change the CSS file under public/build/, it seems always the default font.
Any idea, how could I change the default Font?
I really appreciate any help you can provide.
Chuan
Check if this comment works for your case
Hi ebabeshko,
thank you very much!
I have changed the index.html directly and added my own CSS file. And it works like a charm! :smiley:
Thx!
