How to change colors?
Hi everyone! I’m gonna explain my situation: I have some panels to monitor the status of some services. I want that if a service fails, the panel should display “0” in red, while when a service is active and working well I want a “1” in green. I tried to set some options, , but the 0 in red is never displayed, I see the 0 but it remains green. Some idea?
If it still does not show the colours, check the field type:
Thank you for replying. I tried with “value mappings” and it doesn’t work. I tried to Convert data field to numeric, but again it doesn’t work. Any other ideas?
What is your data source can you share a screen grab of the data view?
Thank you for replying. I fixed my problem, i changed color setting in the palette and now it works well
