Hello team,
I’m trying to create a design where the text inside a Canva panel automatically adjusts its size when the panel is resized. I have a situation where, when I scale the panel (increase or decrease its size), the elements inside it (like images or shapes) scale correctly, but the text inside does not adjust accordingly.
In my case, I want the text to automatically resize to fit the new panel size. I need to know if there’s a way to set the text to auto-scale, so it increases or decreases in size based on the panel’s new dimensions.
