Hello everyone.
English is not my first language so I hope I can explain it clearly ![]()
I’ve been able to log data into InfluxDB from some sensors using the MQTT telegraf plugin, and using Grafana for visualization.
All is working as expected and I am really happy with the results. However, I am just wondering if is it possible to autosadjust the chart “resolution” panels according to the the time range used in the Grafana UI view, like in the stock markets app:
I will try to explain it better with the following, stock market example:
In the images as much time you go back in time less data is loaded and only the most important logs are shown.
Is it possible to do this in Grafana?
I found a work around adjusting the “GROUP BY - time()”, like seen below.
But I don’t know how to link the time() to the time range
For anyone interested I am running Grafana v7.4 on Linux.
Many thanks in advance!
/Andrés
