Latest grafana version, mac os monterey 12.2.1 -
I’m hoping to render a time series visualization with prometheus data within my app plugin. I’d like the visualization to match the one displayed on the Explore page. -
I noticed that the ExploreGraph component utilizes a PanelContextProvider and PanelRenderer, both of which are a part of @grafana/ui. Should I try to utilize these components for my visualization, or is there a better way to go about this? -
What happened?
N/A -
N/A -
N/A -
No -
No, just took at look at grafana source code and foundExploreGraph
