Hi Team,
Is there any way to edit grafana source code and insert new option in Panel.
Can any one help on this.
Hi Team,
hi @harsha20896
What are your intentions for adding an icon to the sidebar? I believe that app
plugins like the Redis App plugin add a sidebar icon.
If you are seeking to edit the Grafana source code directly, then you should be mindful of Grafana’s license, which changed from Apache 2.0 to AGPL3, from version 7.5.x to 8.
