Hi there I would like to add a message to a resolved alarm notification i.e AHU_Status_Alarm Has returned to normal. Currently I get a generic message for every resolved alarm and would like make a specific message for each alarm. Any advise will be much appreciated
Thanks
Welcome @melzb to the Grafana forum.
It sounds like you want to customize the “Resolved” message. Have you worked through this tutorial and examples?
Hi Grant thanks for your reply.
I havn’t worked through the tutorial thanks for the link I will look through this.
