How to access Grafana
I work at a company who is using Prometheus for their metric logging, I believe they also have grafana installed for graphing this data but I am unsure to access it. Is their a default url to look for similar to how prometheus has the /graph url?
If it is a default install then it should respond to http:<ip address or name>:3000. It may not be a default install of course.
Thanks I figured it out, was a bit different since we run it on a cluster
