I would like to know how many alerts can be set up at the same time ?
Like if one sets up around 500 alerts, will be there a problem ?
How many alerts did you ever try to set at the same time ?
thank you
thank you
That really depends on the queries that are being executed for the alerts and how long they take and how often you are checking them. But I think that your time series database would have performance problems long before Grafana had any problems. We are currently running > 100 alerts with most of them on 60 second intervals with little or no performance impact on the server running Grafana.
